Need help with router for cutting minature stile and rails for oak display cabinet. I have a 690 series in PC that burnt the ends when I made my first cut. Yes, I went slow because I questioned whether or not the router was heavy enough for the cut. I use this same router to cut cherry stiles and rails without a problem. That application was 3/4" stock, same as this setup, I cut shoulder cuts of 1/4" flipped and cut the same on the other side and married it with a board that had one single 1/4" cut in the center. Is it the opinion here that my router isn't strong enough to make the minature stile and rail cuts without burning them? If so, does anyone know where I might be able to get a deal on one that will not break the bank. I am considering a reconditioned one. Thanks for the help. Lorraine
