I'm working on a project uses a 1/4" plywood panel about 28" x 18" with plastic laminate on both sides framed with 3/4" wide red oak. Since panel won't be expanding or contracting and the wood movement on the frame will be minimal with the grain, can i just make it a tight fit and glue the panel in, or do i still need a little gap and just glue at the center of each side or use spaceballs?
Thanks!
Thanks!
