Hey guys, i have just recently began to lay out my turning project that i am needing this 4x4 piece for and have decided that a 4x4 will not suffice for what it is that i need. I will be actually needing a piece that is somewhat larger, probably significantly larger.
I'll tell you what it is that i am doing, I am preparing to turn some custom corner decor that i will split into quarters and install in the upper corners of my wall/ceiling junctures of my house to butt ceiling crown molding up to when i install it here shortly.
So actually what i will be needing is a 6" or larger square stock to that will provide enough surface area when cut into quarters that will allow for the crown molding i will be using to butt against a relatively flat area of the upper portion of my turnings.
so some pieces in the vicinity of 6x6 and approx 4-6" long will work great. I guess i would have to pick them up from you due to the fact that i don't believe we could get these pieces to ship in a large flat rate box, well perhaps a 'large' flat rate we might.
I need to measure the dimensions of a "large" flat rate box shortly and post those dimensions up here for if you have several pieces that i could purchase from you i wouldn't mind paying the shipping costs incurred with shipping them in a single flat rate box if say 2 pieces would fit accordingly.
Thanks, Chris
