My first hand plane purchase!!
fried_daddy
MJ
I just purchased my first planes today. After looking around a little online, I decided to look for a used one that had a few years of age on it. Super excited about them. I now need to read up on how to properly sharpen the blade and get the plane set correctly.
I purchased two planes. From what I have read, they are Stanley Bailey. These pics are after I got them home, taken apart, quick cleaning then reassembly. The 5 1/2 looks like it has had a different handle placed on it at some point in its life. The replacement still feels solid though. You guys say you like pics so here are a bunch of them.
1) No 4
2) No 5 1/2 smooth bottom
MarkE
Administrator
Very nice score!
The No. 5-1/2 is an old one, probably a type 6 or 7 based on the three patent dates. It looks to be in really good condition, most of the jappaning is still intact. The sweetheart logo iron is a little newer.
The No. 4 looks like a type 19, also in excellent condition.
Chris C
Very nice score!
I think the three patent dates on the body would make it either a type 11 or 12. Given the SW iron and what looks to be a tall front knob I'd say type 12 from the 1919-1924 period assuming all is original. A very nice plane indeed.
They both look to be in great shape. Well done.
TENdriver
TENdriver
Very nice score!
Mark, I'm with Chris on the the 5 1/2 being a type 11 or more likely 12. The early planes didn't have the frog adjust screw.
Fred, That's a great plane combination to start out with. I'm a huge fan of the 5 1/2 jack. If I could only have one BD plane it would be a 5 1/2.
MarkE
Administrator
You guys are absolutely right. Probably a type 12 and the sweetheart logo iron is the age appropriate.
Don't know what I was thinking. :eek:
You're off to a good start w/ your hand tool collection. If we have one of the hand plane tune-up/sharpening workshops in 2017, you should bring them both.
Chris C
Exactly...trying to use a dull and/or improperly set plane is an exercise in frustration. Lots of free resources out the on the web...some of which are quite good. Paul Sellers videos in particular spring to mind. I would suggest investing in at least one book...The Handplane Book by Garrett Hack. An excellent reference.
https://www.amazon.com/Handplane-Taunton-Videos-Fellow-Enthusiasts/dp/1561587125
fried_daddy
MJ
Very nice score!
All of the planes are in great condition. Tools used to be built to last!
I found a decoding website and that is correct that the 5 1/2 is a Type 12.
That is something I would definitely be interested in attending.
I will add that to my wish list and throw it in next time I place an amazon order to have for reference.
fried_daddy
MJ
I picked up a third plane today. Stanley Bailey No 3. From what research I have done it looks like it is a Type 16. Correct me if i'm wrong. The blade on this one was still sharp and it cut really good when I set it and tried it out on a scrap piece of wood. Pictures of number 3!
Bottom has some slight surface rust. I thought about filing it down with a fine file. Will that hurt the plane any?
I would not take a file to the sole of a plane. To remove rust like that, I use Evapo-rust (I buy mine at Tractor Supply). After removing the rust and re-assembling the plane, you can flatten the bottom by running it across some adhesive backed sandpaper laid on a flat surface like a cast iron table saw top. This will give you the flat surface you need for the toe, around the mouth, and in back of the mouth, which you need for a well performing plane.
Here are some pictures of one of mine before and after Evaporust:
Sorry, can't find any pics of flattening a sole.
Chris C
That appears to be a much newer vintage plane, a type 20 (1962-1967 or newer). Most people would say that the quality of Stanley's planes started to decline after World War II. Doesn't mean it can't be/won't be a good user though. I'd suggest a little more research on the history of these planes before you start your collection. One of the best reference sites to check is Rexmill.com...there are many others.
http://rexmill.com/planes101/typing/typing.htm
Don't do it! A sheet of sandpaper affixed to a flat (truly flat) surface will remove it. A little discolouration or pitting may remain but that won't hurt a thing.
Timmy
Tim
I see the addiction has started. After using the metal planes for a bit, try out some old wooden ones. I like the old coffin planes.
fried_daddy
MJ
Looks nice! What do you apply to the bare metal surfaces after using the evaporust to keep the metal surface from forming a fresh coat of surface rust?
fried_daddy
MJ
I'd also suggest you watch these videos.....this guy knows his stuff.
Restoring a bench plane with Paul Sellers.
https://www.youtube.com/watch?v=RYyV6IUpsYk
Sharpening and setting the bench plane with Paul Sellers.
https://www.youtube.com/watch?v=gE4yVgdVW7s
Chris,
Thanks for the links.
Nice score, Fried.
Thanks.
I will make sure to do that.
