Fact 1. Today is the third woodfest.
Fact 2. I am air-drying my purchases.
Fact 3. There is an active thread on solar kilns.
Fact 4. I know a lot about surveying, but very little about air drying sawn timber.
Fact 5. There is no substitute for cubic inches or experience.
Throughout the web, there are assertions that unless wood is kiln dried, it is not going to work well. Purportedly, AD wood can only reach a MC of 12%, whereas in the kiln it drops to 6%.
My limited research indicates that wood is constantly adjusting to the relative humidity. Here's a clip from Dr. Wengert at WoodWeb:
Q.
Can you post the equation or table that gives the equilibrium moisture content (EMC) for differing relative humidities (RH)? i.e., 10 percent RH = x EMC, 20 percent RH= y EMC, etc. A.
0% RH = 0% EMC
19 to 25% RH = 5% EMC
25 to 32% RH = 6% EMC
32 to 39% RH = 7% EMC
39 to 46% RH = 8% EMC
46 to 52% RH = 9% EMC
57% RH = 10% EMC
65% RH = 12% EMC
74% RH = 14% EMC
80% RH = 16% EMC
91% RH = 21% EMC
Travis and I were discussing this Friday night, and I brought up the issue of the colonial craftsmen who produced some extremely beautiful furniture. Maybe every piece of walnut, cherry and oak went into a kiln before it was worked, but somehow I doubt it.
Even if that were the case, any wood exposed to a higher RH will see an increase in EMC. You don't have to be a weather junkie to understand that anytime it rains, the RH surpasses 90%. Sometimes it rains for days at a time, and the soaked ground keeps the RH up there for some time after.
Point 1: if you're in a hurry to work with your newly purchased wood, there is no question that drying in a kiln produces a workable product more quickly. That is NOT an issue in this posting.
Point 1A. since the rate of water loss is more carefully controlled, wood that has been KD should exhibit fewer drying faults. That is NOT an issue in this posting.
Point 2: no matter how dry you get the wood, to the extreme of oven-drying, it seems that once exposed long enough to higher RH, the EMC will adjust upward.
Point 3: hardwood floor installers bring the product into the customer's house and allow the material to "acclimate" to its surroundings. Anybody with a hardwood floor knows that the joint gaps widen in the wintertime when the RH is low, and in extreme cases, swell and buckle under high moisture conditions, proving that KD material is subject to the vagaries of the ambient RH conditions.
Point 4: most of us do not have a climate controlled shop. Therefore, when the KD wood is brought into our shop, the EMC changes to adjust to the RH in the shop. Even if you run the AC all summer, there are mornings when the temp is 70° and it's raining. Your AC will not be running, since I doubt you set the thermostat below 70°. The RH will rise.
Rebuttable conclusion: Allowing sawn lumber to air dry to a MC of 12%, and then bringing the material into the shop for a week or so prior to milling to allow acclimation to the shop environment, will produce a wood product just as acceptable as KD lumber that is not worked until months after removal from the kiln.
Fact 6. Book learning ain't everything.
Q.
0% RH = 0% EMC
57% RH = 10% EMC
65% RH = 12% EMC
74% RH = 14% EMC
80% RH = 16% EMC
91% RH = 21% EMC
