Well here's what the chair looked like after shaping the rockers:
The 1st task was to mark what areas to avoid in shaping and to take the chair apart (this is like the 100th or so time it's come apart):tinysmile_tongue_t: Here's what the before leg looks like:
Then I marked the bottom around the dowel hole to make the bottom section round:
This is actually a departure from my original design- I was going to have it flared out at the bottom, as you can see in the rough leg. But after looking at a bunch of pictures of other rockers and also looking at how tight my leg-to-rocker interface was I decided to go round instead. So I roughed the shape out on the angle grinder, then used the spokeshaves to clean it up.
Next I cleaned up all of my rough band saw marks on the rest of the legs on the spindle sander in preparation for the next stage (rounding over with 3/4" round over bit)
(this is a tool gloat in disguise-I've been wanting that Rigid sander for awhile and this was the perfect excuse to convince the wife I had to have it)
Next I went to the router: You can see in the next pics 1 finished leg and also 1 unfinished leg-the areas marked in white are the areas that got rounded over:
I left the inside edge with a hard line as John taught us in class that Maloof chairs generally have a hard edge that flows in a circle around the chair:
Here's what they both look like done:
and here's what the chair looks like after today's effort:
you can really see from the back view how much lighter the back half looks now:
Tomorrow I'll finish shaping the front legs (maybe)
Until then........
also-here's a cool link I found this morning looking around for rocker pics-it's a pretty good pictorial on the build process and also has a good "what tools you need list" -notice to John-this guy uses the Veritas dowel shaper too:gar-La;:gar-La;-sorry I just couldn't let it pass
http://www.charlesbrockchairmaker.com/
:BangHead::BangHead::BangHead:clamps-clamps-why do I never have enough clamps
Until then........
