For those of you who have and use this style of blade, what has been your experience as to longivity vs the standard carbon blade.
I recently purchased a couple of bi-metal blades from Woodcraft bands and after a extremely short time, the blade broke right at the weld. I sent the blade back to the mfg. and his comments were " that blade looks like it has had a lot of wear". Let me preface this by simply stating that I hadn't used that blade to cut very much wood and nothing that I consider to be extreme. Wood types ranged from maple to pine in hardness and I was cutting poplar when it broke. All told, I don't imagine I had a total of 1 hr cutting on that blade and was very dissapointed as to the short life to say the least.
Another member and I both bought carbon blades from the same supplier and I haven't had any breakage (don't think the other member has either)with them and have cut ten times the wood with them that I cut with the BM blade.
I could turn this into a rant of sorts but I will forgo that in lieu of your thoughts and experience on this subject.
If a blade breaks at the weld, what is "normally the reason"? Faulty welding, or misuse (take my word on this, misuse isn't even the reason in this case).
For the record, the supplier isn't replacing the blade with a new one, just rewelding the failed one. It will be interesting to see how long it lasts.
