What is one looking to gain by applying oil under a laquer or poly, as opposed to a stain first or even just applying the laquer or poly directly to the wood surface? Essentially, what does oil bring to the situation?
Thanks for all your comments - I should have mentioned I am finishing curly maple and used the oil to make the grain really stand out. It is a complex piece and spraying would make life much easier.
Thanks for the tip (should have thought of it myself) for testing on scrap.
An oil will give wood grain a deeper more 3D look. A laquer or poly finish sets up on the surface before it has time to penetrate. By using an oil then a laquer/poly, you get the grain poping effect of the oil combined with the durability of a film forming finish. The key is to let the oil dry completely, at minimum a week, before applying your desired finish.
