Hey guys, I'm looking for some ideas on ways to square up some turning blanks I have to use for inlays or decorative banding. They are approximately 1/2" to 3/4" square and measure between 9" and 12". The problem is that none of them have a square/flat edge. They aren't really warped or bowed, but they aren't straight either.
I was thinking of attaching several of them side to side and end to end with double-sided tape to a longer, wider piece of 3/4" plywood and running them over the jointer to at least square up one side. I thought that a few shallow passes would probably work, but I am concerned over the safety factor. Is the tape strong enough? Should I try gluing them?
Anyone with any experience on jointing/planing small pieces? I don't have a planer or drum sander. I have considered a belt sander or ROS to sand them flush, but this would be time consuming at best. Hand tooling is another option I've read, but I have neither the skills nor the tools to do so.
Thanks!
Thanks!
