Last night I milled some walnut and glued up to make a 4x4x43 inch post for a floor lamp. Today I marked the tapers, cut on the BS and cleaned up with the jointer. Looked perfect until I stood the post on end and realized I DumbA'd out and forgot to cut the ends square after the glue-up and before the taper.:eusa_doh:
I took a bevel and recorded the angle of the"good" sides and transferred to the base. Any recommendations on how to cut the bottom and top square? I need to remove on the order of 1/32nd or so on one edge and flush on the other.
I thought about shimming one edge to get the bottom at 90 degrees and shaving with the CMS along my line but I am not sure if that is doable without the post moving. Wanted to ask here before it becomes a 40 inch post after successive mis-cuts!
BTW the new BS did a superb job on the taper! I can see that saw becoming a good friend. I use it for a lot of tasks that used to go to the TS.
Chuck
Chuck
