I was really looking forward to making a lot of progress yesterday. I finally completed two things in my shop I had been meaning to do for a long time. I attached a dust collector to my jointer and made a permanent work station for my miter saw.
Things did not go well at all. I had rough dimensioned the wood at my new miter work station, face jointed and planned all the wood for the two carcasses. I edge jointed a number of boards in prep for panel glue up. Decided I needed to go ahead and start glue up as I do not have enough clamps for all the panels I would be making. This is when I discovered I had a problem.
All of the edge joints looked like my jointer fence was leaning at about 80 degrees rather than 90 degrees. Checked the fence and it was dead on 90. These boards are not that long, 42", but I decided to check my technique any way. I could not obtain a good edge. Started looking for a problem. Finally found a blade edge that was visually a little high. Reset the blade and tried again, no luck. Then decided to reset all the blades, no luck. Started checking the infeed and outfeed tables with a dial indicator. Could not find any problems. Got the manual out and did a little reading. Took the fence off and reset all the blades again. I used the dial indicator and the stick method. Set the height of the outfeed table above the blades per the manual. Ran a few more test pieces, things are now worse. I have a good 90 degree edge on the boards but other problems have now appeared. I run the board through one time and the results indicate a low outfeed table. Don't change anything, run another board and the results indicate the outfeed table is to high. Run a board through again, no changes, and I get a "sprung" board result.
I am going nuts by this time:kamahlitu.
The jointer is a Delta 6" Professional that is about 3 years old. I have changed blades and set up a jointer many, many times and I know that they can be frustrating at times. This has gone way past frustrating.
I just bought a glue line rip blade, Frued, and so I did finally glue up a few panels but I still need to resolve what is going on with the jointer.
To add insult to injury when I went to close up the "shop" the garage door opener that I put new guts in about three months ago died.
It only gets worse. Went into the kitchen and the new $260 pump and motor in the dishwasher has leaked water all over the floor.
It gets even worser! Today my son and I have to go to court and listen to why the driver and the owner of the tractor trailer that T boned my son, after running a red light, should not be held libel.
When my wife came home and found I had broken out the 18 year old single malt scotch she did not even bother to ask how my day had gone.:rotflm:
I made way to much sawdust yesterday but that is still better than not making any:eusa_danc:eusa_danc:eusa_danc.
