According to Christian Oltzscher, head of Festool USA the Kapex will be coming to the US in late spring or maybe summer.
Guestimates of thew price: $1000-1200.00
Here are the specs:
Finally a sliding compound mitre saw that merits the Festool brand name.
Applications
Trimming skirting boards and cornices up to 120mm in height
cutting boards and panels up to 305x88mm
Trimming crown mouldings up to 168mm in their 'original wall position'
Trimming square timber and beams up to 88mm thick
Trimming non-ferrous metal and plastics (with correct blade)
Cutting along the bisector without making calculations Features
Twin-column guide for accurate cuts
FastFix blade changing
Precision angle transfer via bevel and dual-line laser
Compact, lightweight design for convenient transportation Technical data
Power consumption - 1600w
Idling speed - 1400-3400rpm
Saw blade dia. - 260mm
Cutting depth at 90/90deg - 305x88mm
Cutting depth at 45/90deg - 215x88mm
Cutting depth at 45/45deg (left) - 215x55mm
Cutting depth at 45/45deg (right) - 215x35mm
Special cutting depth at 45/90deg (right) - 20x120mm
Crown moulding diagonal cut - 168mm
Inclination angle - 47/47deg
Mitre angle - 50/60deg
Dimensions (WxDxH) - 713x500x470mm
Dust extraction connection dia. - 27/36mm
Weight - 21.5kg
Scope of delivery
Operation tool, HW universal saw blade Z60, bevel, workpiece clamp.
(part No.s 240v - 561285, 110v - 561286)
Doug
Here are the specs:
Choose Voltage:
240v 110vFinally a sliding compound mitre saw that merits the Festool brand name.
Applications
Weight - 21.5kg
Scope of delivery
Doug
