I'm looking for some recommendations on what might be causing this and possible solutions.
We've got an undergound/wireless dog fence (I'll omit the dist/brand info as I don't really think it's pertinent) that we've had for almost 3 years. Up until recently it's been pretty problem free but starting back a couple of months ago, maybe April, we've been having some issues with the controller "frying". Unfortunately we're on the 4th replacement controller since then and it just went out over the weekend after being installed back on 8/1. After the 2nd replacement went out after a couple of weeks the rep came out to install the 3rd replacement himself since he was concerned about how many he'd replaced in a short period of time. The new control unit he brought "popped" as soon as he plugged it in, so he really wasn't pleased at all. He took the 2 dead units and was going to have them examined by their techs to see if they could find out what was blowing them. The fourth/current unit he shipped to me to use while they checked out the other two and I hooked it up. The also provided me a free PanaMax underground fence surge protector to hopefully prevent further issues since they're convinced a surge killed all the units.
A history of what's been done/not done.
1) All the controller unit transformers have always been plugged into a surge protector. In fact I've used 2 different ones in case there was an issue with one and that had no effect.
2) The units transformer has always been plugged in the same 110v garage outlet since it was installed.
3) My irrigation controller, which is fairly sensitive itself, is plugged into the same outlet and most of the time in the same surge strip (or none at all) and is still working fine.
4) The Panamax fence suppressor protects against surges from both sides of the unit (house current and the buried wire antennae) and is supposedly one of the best on the market with a very low failure rate.
5) The techs finding was that the two units he checked were both fried by a house side surge and not a fence/antennae side surge.
6) The 4th unit and PanaMax protector were installed with the old/original power pack/transformer since they didn't ship me a new one of those like they indicated they would. I think this might be where the problem lies.
7) This circuit is shared by some of my ww'ing tools when used, but I've not tripped a breaker or had any issues with the tools. I run the Delta contractor TS and Jet 1.5 hp DC at the same time off that circuit but haven't seen any issues there.
The rep obviously is tired of replacing the controllers at no cost under warranty, as are we since it means the fence doesn't work while we're waiting for them to provide replacement parts. He thinks we should have an electrician come out and investigate our home wiring for a "surging issue", but I'm not sure if that's needed or what I would ask them to check since nothing else on the circuit seems to have an issue. They're sending someone out tomorrow with a new controller and power pack/transformer and they'll install this one and test it.
Questions/concerns:
1) Shouldn't the surge protectors have in theory prevent any house side surges from getting to the controller?
2) It's odd that there have been failures now on 3 separate surge protectors.
3) Is it possible that the power pack/transformer was messed up by a surge during the first failure and it's now what's causing the surge to the controller since it's all that is between the surge protector and the controller?
4) I've offered to try plugging the unit into another 110v outlet that's on another circuit, in fact it's on anther service panel, hoping that will solve the issue or at least rule out something else. Think will help any?
5) Should I be considering calling an electrician to check the garage circuits or would that be a waste of money since nothing else in the house or on that circuit is having any issues?
I'm open for any suggestions on causes or solutions.
TIA,
Brian.
Questions/concerns:
TIA,
Brian.
