7 yr old whirlpool dryer , nuttin' fancy , has worked just fine until this AM when it quit mid-cycle
Completely dead .....will not even grunt when turned on :no:
There's power to the machine and switch ohms out just fine. No loose wires or anything burned or obviously wrong underneath . Belt is not broken Checked door switch .
Motor shot maybe ?
I have a meter and can do basic testing but nothing real fancy
The thing is just dead ......any ideas ? :dontknow: :help:
*Update
Motor is not shorted . all thermostats I could find have continuity . One very small round device located on the back wall does not have continuity ......could this be a fuse or limit switch that is open ? I would assume on a cold dryer this would be closed along with everything else . Schematic shows no " normally open " switches :dontknow:
Motor shot maybe ?
*Update
