Yesterday, my wife was cleaning out the oven with easyoff and a idea came to me. Why not try that stuff on some gunked up carbide tipped tablesaw blades that I was going to take to get sharpened? So I got me a container that was a little bigger around than the 10" tablesaw blade and sprayed both sides with easyoff, Then I put the blade in the container to soak for about 15 mins.
Much to my surprise the blade came clean with just a little bit of scrubbing with one of those non scratch green pads my wife uses to scrub pots with. Then I tossed the blade into the saw dust pile under the tablesaw to get it good and dry. I then blew it off with the air hose and mounted the blade in the tablesaw. Much to my surprise it cut like 100% better than it did before and not a hint of a burn mark on the wood either So I cleaned 5 more tablesaw blades and my dado stack just the same. Looks like my trip to see the sharpener guy will have to wait till my blades are really dull and not just gunky. That little can of easyoff and a little bit of elbow grease saved me some real $$$.
I also cleaned a bunch of carbide tipped router bit's after taking the bearings off first, easy off worked great on the router bits too.
Thought I would pass this alone... I've seen cleaning solutions in wood mags but never tried any of it. You can pick up a can of easyoff and those non scratch green pads at the dollar store real cheap. Sure does beat sending them off to the sharpener.
Here's what I used
Heavy duty green scubbing pad ---> http://multimedia.3m.com/mws/mediawebserver?66666UuZjcFSLXTtMxTcoXfEEVuQEcuZgVs6EVs6E666666--
Here's what I used
