I made an interesting discovery today, which everybody else probably already knows...
Whenever I use a sanding sealer (shellac), and do the sanding between coats, I typically use a small electric sander that takes rectangular sandpaper. Unfortunately, the shellac leaves some gummy deposits on the sandpaper within a few minutes, which requires several sheet changes while sanding.
Today I filled a large glass jar with denatured alcohol, and stuck the sandpaper pieces in the jar as they started gumming up. Within a few minutes, the shellac deposits were gone and the paper was not damaged.
I'll probably try hand sanding on the next coat (which may not gum up the paper), the the electric sure is nice for the speed.
