Many thanks for the replys. Here is the skinny. I purchased some solvent based black lacquer to spray on a desk I was building. Dummy me, I had no experience in spraying, so after a bit of research on spraying, I jumped right in and started spraying the lacquer in my basement. I was wearing a mask, so I could not tell that it was stinking up the entire house. When I stopped spraying and took my mask off I realized my BIG mistake. I decided that I would never spray solvent-based lacquer inside ever again. Well, what to do at this point, I have a desk, partially sprayed with solvent-based lacquer and I need to finish spraying the thing. I did some more research and decided maybe one option was to switch over to a waterbourne lacquer from Target Coatings. I have purchased the TC clear lacquer, some Mixol black to color, and a gallon of polyurethane as a topcoat...... but I am not sure using this over the solvent-based lacquer is possible.
I guess I have another option now that the weather is warmer and that is to finish the project with the solvent-based lacquer by spraying outside. Anyway, now you know the rest of the story.
