One of the next steps in my current project is to build 7 drawers. I know that I said 8 in my last thread but another member pointed out there were only 7 holes, and that is when I realized I could not count.:dontknow:
It is funny how each project we tackle gets more complex. In the past I have only built one drawer. It was all ply construction, using a locking rabbit joint and had a false front. There will not be any false fronts on these, so I want the joinery to look better as well as be stronger and decided to go with half blind dovetails. Joe Scharle mentioned the I.D.I.O.T. rule in another post and it makes sense, so any more tips you would like to talk about?
Any pitfalls to avoid?
Ideas that would make the process/learning curve go smoother?
I do have the Porta Cable jig and purchased it a couple of years ago for this project. I did play around with it when I got it and have the setup close. Several have suggested poplar for sides and backs. I picked up enough for at least an extra drawer plus dialing in setups. It will probably set in the shop 2 to 3 weeks, if not longer before I start milling it.
