With two threads currently active on bandsaw setup and blades, I'd like to offer the following. No brag, just fact.
Over the last weekend, I spent a half hour tuning up my Rikon 10-345. It has a nearly new TimberWolf ½" 5TPI blade. I'm not sure what note the blade makes when plucked, as I am tone deaf. I never could get the "flutter" thing to work, so I just tension the blade until it feels right, and with my limited experience, that's sort of a WAG.
So, after reading the bandsaw threads, this afternoon I decided to do some veneer-type resaw and see how well it worked. I used a piece of cherry that was a firewood pile rescue that had spent over a year in the shop. Earlier, I had jointed one face and one edge. The board was 5" wide and about an inch thick.
The first slice I took merely cleaned up the ragged face. The second slice was somewhat thick, and the third slice was significantly thinner.
Results: On the thicker slice, it started out at 0.12, skinnied down to 0.10 in the middle and was 0.13 at the other end. The thinner slice was 0.04 at the start, 0.03 in the middle and 0.06 at the other end. Each edge compared with the adjacent edge within 0.01".
I did not take any special care, did not use a featherboard, used the factory Rikon fence with an MDF adjunct, and just slid the board through. No attempt to compensate or adjust for blade drift, just shoved it on through the blade.
I don't know if these results are normal, exceptional or horrible. It's just what the saw provided. If anyone else has performed a similar experiment, it might be interesting if you post your results. As always, YMMV.
