A while ago I asked for some help fixing a stuck tension nut on my 14" delta bandsaw: http://ncwoodworker.net/forums/f29/tension-nut-1950s-delta-14-bandsaw-33078/
Thanks for all the comments I received. I worked the blade off the wheel using the tracking adjustment as recommended.
Unfortunately the nut was stuck up in the body of the tension bracket so I could not split it off.
Bruce (junquecol) had offered a replacement quick adjustment thread/knob. I took him up on his offer and met him at his house last night. We (Bruce) ended up having to hacksaw off the knob to get the bolt/nut free of the housing. After that he replaced my old bolt with his quick adjustment knob:
The new one works great. The crank is higher which keeps from busting your knuckles. The handle also makes it easier to count the number of revolutions. This is nice if you de-tension your blade after use. It makes it easier to get it back to the proper tension.
I also took Bruce's advice and put a strip of UHMW PE under the bolt. This makes it turn much easier and avoids grinding into the cast iron.
So the moral of the story is to add a little grease (Bruce used white lithium) to this square nut to keep everything moving smoothly. It is also great to have NCWW friends!
Thanks again Bruce!!!!
Salem
View image in galleryThanks again Bruce!!!!
Salem
