Bandsaw blade recommendation
Kelly
Kelly
For years I have been buying bandsaw blades from BS Tools in Toronto, based on a recommendation from Michael Fortune. I leave a 1/2” blade, 3 tpi skip tooth on my saw most of the time. But they have folded. So, I need a recommendation on a new source for a good general purpose blade.
Anybody ?
NCPAPOF2
Curtis
I have used Timberwolf for about 15 years. When I bought my new Rikon I decided to try Lenox bimetal. Have to say I am a little disappointed. Do not seem as sharp initially which is the usual impression by users, but they stay sharp longer time will tell. Test cut in a pine 2x4 was very smooth, 3/8" 6tpi, but seemed to need more feed pressure. Going to process some scraps to make bandsaw boxes so we'll see after somecreal life usage.
tvrgeek
Small plain steel blades, I use Bandsawblades.com ( Stumpy Nubs recommendation) but had thump-thump on larger than 1/2 inch. 1/4 and 3/8 have been fine. I have heard Union does a fine job. Most of the band stock actually comes from the same few suppliers, so the retailer is usually only welding and packaging. I put a Laguna carbide on for re-saw and it made a HUGE difference. Steel blades always need a hone on the back side and a quick de-burr on the teeth. I think Olson, Lennox and Starret actually make the blades. Could be mistaken. Well, in the vernacular, wrong. :) Harvey 14 inch, 3 HP.
