I love it.... I'm relaxed just looking at it. You did a beautiful job. :eusa_clap I hope you stack cut that because it is sure to be a good seller.
Thanks all!
You can bet I'll be stack cutting it the next time I do it. I get nervous stack cutting the very first time I do a complicated pattern. I'd like to do it on thinner wood (this was 3/8 BB ply) but some of those cuts are SO fragile I just don't see anything less than 1/4 being feasible. I certainly won't be trying it on any solid pine or hardwood.
You will be surprised how strong good quality 1/8 BB or other quality 1/8 plywood is when stack cutting. If you use a zero clearance insert I do not see why you could not cut that 5 or 6 high. I would be happy to show you.
I may have to take you up on that one of these evenings after work. I'll have to find my zero clearance insert and drill the center.
