I was having coffee this morning and had a brain storm.
You see all them jigs in your shop, what if you could put three of them in a 3/4" PVC pipe about 24" long? And mount them on the side of your router table.
Go down to the hardwear store and buy three square rods, 1/2" - 3/8" and 1/4" (or the size box joints you need), cut them the leignth of your router table (you will have to figure the size) and drill a hole, say an inch from the end,and drill matching holes in the router table top,at the bottom you will need a hole for each size, it will povot at the top hole. Before you drill the bottom holes,mount each size and adjust for that size from your router bit. Then put machine screws with wing nuts to hold them in place.What do you think?
