Zoom, Zoom, Zoom
Steve D
Member
Steve DeWeese
Here's the latest update - test fit of the power plant. :mrgreen:
Yes, I'm dying to run it, no I haven't yet.......
Steve D
Steve D
Member
Steve DeWeese
It's a 3HP, 3450 RPM Leeson, I couldn't get a permit for the nuclear reactor. :lol:
Canuck
Wow Steve. I really like the way you mounted the motor to the casting!:eusa_clap
How did you ensure the alignment of the top and bottom pulleys?
Looks like it may be getting close to in-service! Is this all considered a "dry-fit" prior to paint?
Very, very good restoration!!!!!!!!!!!!!!!!!!!!!!!!
Steve D
Steve D
Member
Steve DeWeese
Thank you, yes - dry fit before paint. I had the bracket custom made and took careful measurements for alignment. I had some play in & out with each sheave so I was able to get them dead on.
sapwood
Roger
Heavy, heavy, heavy :cool:
Pretty sure we'll know when you pull the switch. It's definitely going to affect the power grid statewide :lol:
Great job :mrgreen:
Sapwood
Steve D
Steve D
Member
Steve DeWeese
I need to verify clearance when I can set the beds back on, I think I can stub up a piece of conduit and mount the switch directly above the motor and behind the fence. The only problem now is the freakin' beds are so heavy, I need help just to move each half around.
User not found
You know where you can get a true "Heavy lifter" to help you out anytime! Just give me a holler!
D L Ames
D L Ames
Looking good Steve.:icon_thum How do you add oil to the bearing reservoirs? I bet that baby is going to purr once you get it running.
D L
Steve D
Steve D
Member
Steve DeWeese
DL,
There are holes in the top bearing cap. You can either add a few drops before use each day or attach a snap cap drip oiler that will slowly add oil. There is a felt wick in the reservoir below the bearing that is in contact with the shaft and wicks oil up from the reservoir. The experts tell me that I should use 30W detergent free oil. I'll probably just heep an oil can on the blade guard when not in use to remind my feeble brain.
D L
michaelgarner
Michael
Yup,,NCPete,, I was eyes wide open to see the new miata or something,, maybe a monster miata 5.0. someday i will make a tiny rocket,,someday.
cpowell
Chuck
Geesh, what a problem...the beds are SOOO HEAVY!!!
Go on, rub it in some more, Steve!
That's one nice looking machine. I can't wait to see it painted...maybe with a light coat of chips and SAWDUST!!
The gloat that never stops giving! :lol: :lol: :lol:
Chuck
Steve D
Steve D
Member
Steve DeWeese
:mrgreen: McRabbett came over tonight and helped move the tables so I can get them prepped. I'm guessing the infeed goes about 150# and the outfeed 200. It's nice to have a fellow woodworker nearby that doesn't mind a little heavy lifting.:icon_thum
Chuck
