I got the new 15" Delta planer pretty much cleaned up (gooey oil vs cosmoline) and put together (I used my I-beam hoist again to lift it onto the stand.
) I still have to do a little fine alignment of the infeed/outfeed roller tables but a test cut seemed to go ok. I still need to mount the step caster to complete one of my homemade mobile bases, but I need to get a piece of square steel tube first. I will be adding a Wixey digital thickness gage also. I really need to make or buy a DC connection because this thing really spits out the shavings!!!!
I have one concern/question- when I ran a test piece of pine through the jointer the serrated feed roller put marks in the board. This is not a problem when taking off material, but I am concerned if I run a piece that is at, or close to, final thickness I'll get surface marks. Anyone else notice this on 15" or wider planers?
This sucker is HEAVY, substantial (never looked that way in pictures), and appears very well made despite the country of origin (rhymes with Dinah). It is so much quieter, both running and planing, than my lunchbox planer!
With the infeed and outfeed tables folded down, the footprint is not much larger than my lunchbox planer and stand. The little black box in the lower left of the stand is my wheel mounting bracket.
