Writing on walnut
William Roscoe
William
Got some walnut logs I'm cutting into smaller pieces but nothing shows up on this dark wood. I need a white pencil:). Any ideas??
tarheelz
Dave
I try to rely upon my knife for lines and such. I use chalk for broader notes (e.g. lining up boards for a table).
How about a white colored pencil for marking edges and the like? Might be hard to get precision with that.
NOTW
Notw
I use white pencils, available at most craft stores. they show up great on walnut
bluedawg76
Sam
i've never found pencils to be fine enough for a cut line -marking faces and stuff sure, but a knife is superior in my clumsy hands.
Tarhead
A regular .5-9mm mechanical pencil line will show up on dark wood with a side light. Overhead fluorescent light washes it out. I use a marking knife then white or yellow chalk to highlight the mark (old eyes:mad:) for fine work. For rough cutting, chalk or a yellow grease pencil. White, yellow, light blue .9 mm Bohin sewing pencil refills from my wife's sewing basket will work too but not a good idea for peace and harmony in the house.
William Roscoe
William
Good ideas, for sure. I think I'll try hobby lobby first. I'm trying to mark on the end grain, cutting 5 equal sized triangles (72 degrees). Then I'll I should be able to turn it and get the grain as even circles, top to bottom with dark wood at the bottom and light colored sapwood on top. Saw this in a book called TURNING GREEN WOOD. I'll take some pictures and we'll see if this really works!
KenOfCary
I tend to use white pencils - Hobby Lobby, Michael's, many craft stores carry them.
But another option is to put blue painter's tape on the wood and mark on the tape.
William Roscoe
William
Pictures of a walnut tree I was lucky enough to get. Plan to use this only for turning!
Truefire
Wow! That is some beautiful wood...lucky you! :) Some of that chucked + chisels kissing should make you smile.
William Roscoe
William
just got around to turning 4 bowls yesterday and put anchorseal on them. I also cut a 6" section off of 1 of the larger pieces and I ran out of time but I'll go back and mark and cut it into sections on the bandsaw. This will be my first time turning wood this way. I'll post some pictures when I get them rough cut. I may even try using the microwave on one, like in the book I mentioned earlier.
