I am getting a new 20" planer and wondering if I need to beef up the flooring in my shop. My current 15" planer is ~655 pounds, the new machine will be ~875 pounds. The 20" planer will be on a mobile base.
My shop is on a crawl space with 3/4" Advantech flooring on 2x10 joists, 16 oc. There is a main beam down the center of the building made from three 2x10 with another board (2x6?) on top. The center beam sits on two piers and the outside walls. The beam span is ~26 feet, the joists are ~11 feet from the beam to the outside walls. The planer will be approximately centered over the main beam about 3 feet from the outside wall.
So the question is, do I need to add more support to that section of the floor? And if so, what is the best way to do that?
