Looks like some sllightly older but very well maintained stuff - I have to work so I'll miss all of it, but home someone finds some good deals
LINK: http://www.auctionzip.com/cgi-bin/auctionview.cgi?lid=1349111&kwd=&zip=27410&category=0
List below from the auction site:
Delta ShopMaster 6" Disc Sander, Model SA446
Jet Slow Speed Wet Sharpener, Model JSSG-10
- with Tormek SVM-100 long knife jig
- with Tormek SVD-185 jig for gouges and turning cutters
Rikon 34" Floor Radial Drill Press, Model 30-251 with Drill Press Laser Model 146709
Rikon 14" Deluxe Woodworking Bandsaw, Model 10-325 with thin and thick bands
Delta ShopMaster 6" Variable Speed Bench Jointer, Model JT160 on Shop Fox Deluxe Tool Table, Model D2056
DeWalt Woodworker's Table Saw, Model DW746 with DeWalt Mobile Base, Model DW7460
- with JessEm MiteRExcel Precision Miter Gauge, Model 07100
- with Woodsmith Aluminum Box Joint Jig
- with one push stick, two push blocks and 16" push block
- with Irwin 10" 80T Carbide blade
- with DeWalt 10" Woodworking Series 40 blade, DW3218TK
- with Systi Matic Dado Set, Model 37142
- with 8"/12 teeth dado blade & dado blade insert
Delta 14" Variable Speed Wood Lathe, model 46-715
- with Supernova2 Chuck
- with 8-piece Woodcraft turning tool set & carry case
- with Robert Sorby Sandmaster 410 and abrasive discs
- with Robert Sorby 3/4" Box Scraper 829H -- 2 of these
- with Robert Sorby 3/4" Curved Scraper 828H -- 2 of these
- with Robert Sorby Multi-Tip Hollowing Tool RS200KT
- with Robert Sorby Midi Hollowmaster RS130KT
- with Robert Sorby 3/4" Spindlemaster 812H
* All Robert Sorby tools in original cases
1 Porter Cable Router, model 894PK
1 Porter Cable Plunge Accessory
Router is mounted on JessEm RoutRTable Stand, Model 05001
- with JessEm Master-R-Lift
- with JessEm Rout-R-Lift, model 02001
- with JessEm Phenolic Table top
- with JessEm MastRFence, Model 04001
- with Porter Cable Dovetail Fixture/Jig #4112
- with 30 different router bits
- with Jasper Perfect Circle Guide, Model 270
Delta 13" Two-Speed Finishing Planer, Model 22-580 with DeWalt Mobile Planer Stand, Model DW7350
Jet Air Filtration System, AFS-1000B (needs new outer filter)
Delta ShopMaster One H.P. Single-Stage Dust Collector, Model AP400 with a lot of extra hosing and hose clamps
Smaller tools:
DeWalt Plate Jointer DW682 with different size biscuits
DeWalt 7 1/4" Heavy Duty Circular Saw, DW364
DeWalt Variable Speed Orbital Jig Saw, SW318
DeWalt 1/2" Heavy Duty Hammerdrill, DW511
DeWalt Heavy Duty Work Site Radio/Charger, DC011
DeWalt Cordless Adjustable Clutch Driver/Drill, DW928
Smaller tools:
