I'm making an interior decorative access door with final dimensions of about 30" x 80" x 2 3/4" thick. Overall, my goal is to reduce noise as there is an AC unit behind the door in a basement. My plan was to make a wooden frame filled with Roxul (sound deadening insulation) and then 1/4" plywood on the front and back. I'd like to encase the front and edges of the door with 1/2" Walnut to make an 'old-style' looking door with some large decorative iron hinges. Ideally it would be made from solid stock but that is just not an option as I don't have access to 12/4 Walnut and really would like to keep the weight down from solid wood.
So, my question is related to wood movement since I'd like to attach 1/2" thick walnut strips to the plywood base. The walnut will be in strips about 3-4" wide and almost 7' long.
Is there a correct way to attach the walnut and allow for movement? It will be in a conditioned space with fairly stable humidity but my concern is that the wood movement could cause the entire door to warp.
Thoughts?
Thoughts?
