Hey, I am reasonably smart, but no genius by any means. When I don't understand something, I do a little research. ( so a lot of time researching) Doing some minor work on my home, built in '92, I find electrical, framing, HVAC, and plumbing code errors as well as just plain bad practice. Why is it that "professionals" can't do it correctly?
A good example of bad, ignorant, or don't care is I just paid a bunch of money to a major plumbing company to re-plumb my house eliminating the old PB tubing in favor of PEX. At the same time, I put in all new Delta fixtures. I would up with only 1.8 GPM flow into the tub. That means it takes over 20 minuets to fill a tub, so it would be cold before one ever got into it. Called Delta. No response. Asked the plumber " that does not look right, but no idea" . Talked to the major supplier where I got the fixtures. Never heard of it, but were nice enough to give me a new cartridge. Went up to 2.1 GPM. This is the TUB, not the shower. Internet search. All kinds of clearly wrong stuff, but a few leads. I disassembled the cartridge and measured the ports. According to Bernoulli, the fixture will never flow more than about 5 GPM with full on for hot and cold. Delta advertised 6.3 "maximum" @ 60 PSI. So, well sure, it won't flow 6.3. It can't! Misleading advertising.
Found all the tables for pressure drop in PEX systems. Doing the math, I need to increase the inlet regulator at least 5 PSI to make it provide 60 to the fixtures. Plumber set it to 55.
So, I drilled out the exit ports and got up to 2.5. Better, but unusable. Then I read the instructions again. It says to only use copper from valve to tub. Never use PEX. So I followed the instructions. 4.5 GPM with hot only and no longer dribbles from shower head filling the tub. Post valve, the pressure is very very low so just the small restriction of the PEX fittings causes the issue for low flow and the diverter venturi not to work completely.
Why does the "professional" ( in quotes as they clearly not very professional) not know this? It is their JOB to know this.
So I give half a thumb up for the plumbing supplier to stand behind the Delta warrantee. Only half as they knew nothing about flow issues.
A total thumbs down to Delta for ZERO customer support.
A total thumbs down for both ignorant and sloppy work for the plumber.
Oh yea, the Rennai thermostat went bad. First recommended "pro" never responded. Dominion ( installer) menu does not allow you to get to service, just sales, Only the third on the list actually responded and gave me an appointment.
Ironic, I was going to do it all myself, but crawling around under the house is getting harder and harder. I have worked with copper but never PEX so I paid a professional. In the total time involved, I could have done the work myself is less hours than it took to research and correct the mistakes they made. I still have more work adding supports for the pipes under the sinks flopping in the breeze, had to replace where they ran the plastic through the old copper sharp edge supports, and adjusting clamps so the tubes don't twist the shower fixtures.
I still have to re-duct the bath exhaust fans. They just ran the tube into the soffits. No actual vent. I had the old water heater in the crawl space replaced by a vented tankless. Yea, it was an old school taking air from the house for combustion!
I think I have all the electrical code violations fixed. Most were original and should never have passed. A couple look like previous owners. I fixed the structural errors in the framing under the baths that never should have passed and corrected some just plain stupid issues. Clearly the framers did not look at the floorplan for either plumbing or electrical. 2 x 8s notched to 3 inches! Oh yea, one stool was only 13 inches center from the wall. Should never have passed.
