I made myself a bent hollower/undercut tool. I have a small sorby - 3/8" round steel but wanted something larger and longer. I used 1/2" square steel and did the bend in my dad's forge, then drilled and tapped for a screw to hold a carbide cutter. The cutter is 1/2" round. The problem is when I use the tool it wants to torque down instead of cut. The bend is about 5" long and half that deep. I have cutter lined up with the straight part of the steel as best I can. I am wondering if a) it is off or b) the bend is too deep. However, in theory it shouldn't matter how deep the bend is, so long as the cutting edge is lined up with the long axis of the tool, no? The tool in question is the larger bent hollower in this pic. The smaller one is the Sorby that I put a new handle on. I am also wondering if I need to relocate the cutter on the tip. I can post a close-up if I need to.
