1.
2.
3.
4.
I’ve had these boards stacked and stickered in my shop for probably ten years so they should behave predictably when I joint and plane them. They came from a large walnut that was taken down in Tanglewood County Park. It was sawed, air-dried and kiln-dried by a sawyer and woodworker near Clemmons.Very niceHeat and humidity has slowed me down, but progress continues on a walnut drop-leaf table with swinging cabriole legs. This week I’ve been shaping the knee blocks.
View attachment 238015 Time to take a heat break—starting to drip sweat on the work.
If you’ve never used a spring joint you’d be surprised at how little pressure is needed to close the joint even with ~13” boards.
After rough scraping the squeeze-out I use a sharp cabinet scraper to level the joint. Pen tip shows the glue joint after cabinet scraper.
At left is a sample cutoff to test the setup.
The hinge is mortised into the underside of the top and the hinge barrel is buried in a mortised trench so that the axle falls at the center of the arcs.
The last thing before sanding is to work the table edge so that it makes a nice complement to the rule joint.Thanks Charlie. I always wondered how that worked and never had the opportunity to learn. Still not sure I could do it but now I understand what goes into the process.After gluing up the fixed panel top the next job is cutting the mating parts of the rule joint. I use a 1/2 inch radius for the cove and round over. The top is about 7/8” thick and that looks to be right proportional to the thickness.
View attachment 239802 View attachment 239803 At left is a sample cutoff to test the setup.
At right is a dropleaf hinge. It is upside down but it shows that it lies flat as it needs to do. The distance from the hinge face to the center of the axle determines the center of the arcs from the bottom of the tabletop.
View attachment 239804 The hinge is mortised into the underside of the top and the hinge barrel is buried in a mortised trench so that the axle falls at the center of the arcs.
View attachment 239805View attachment 239806View attachment 239807View attachment 239808
With the hinges attached I check the swing of the joint for binding and adjust as necessary for a free swing but close fit so the joint is clean when in the dropped position. I cut the joint parts with a router but make adjustments on the cove side with a round handplane. The cove side is hidden so it’s handy to relieve any binding on that side.
View attachment 239809 View attachment 239810 View attachment 239811The last thing before sanding is to work the table edge so that it makes a nice complement to the rule joint.
Leafs down it has space for two—just my wife and me normally.
Leafs up it will seat four but still fit into the breakfast nook.
