Nice. Reminds me I need to make a bathroom wall cabinet and shelf unit. Just need some cooler weather.Some shelves for our guest bathroom.
Elm from a neighbor's tree.
Now to see how long before SWMBO removes the triceratops.
What are you using for a collection system.. ?I just finished a simple dust collecting table for my drill press sanding drums. The star nuts hold it down to pre-existing slots in the shop-made table.
4" flex hose from my DC. With 1/4 gap all around the 3" drum literally no dust ends up on the top of the table.What are you using for a collection system.. ?
Mitch - do you always use a 3" drum? other smaller sizes? If you use smaller sizes, do you try to close the gap from drum to edge at all?4" flex hose from my DC. With 1/4 gap all around the 3" drum literally no dust ends up on the top of the table.
The 3" is the one I use most often and I wanted to make this out of scraps so I built it with what I had on hand. If it ends up not working well with the smaller diameters I'll look into some magnetic router table inserts and add some magnets to the table.Mitch - do you always use a 3" drum? other smaller sizes? If you use smaller sizes, do you try to close the gap from drum to edge at all?
I think the commercial spindle sanders use insert rings that are partially cut out to both provide support close to the edge of the drum AND allow air flow through. I can't speak to the effectiveness, as I don't own one but I have seen them. They use interchangeable rings for different drum sizes.
Thanks.. just remember the rpm's an dia of the drum your using.. vs. the rpm the drill press is set at..4" flex hose from my DC. With 1/4 gap all around the 3" drum literally no dust ends up on the top of the table.
I have seen people use the magnetic sheet's for signage on their router tables. Don't know if that works or not. Cover the whole table.. an allow for a small square in the center to accommodate the bit size being used. Just change out the squares for the bit'sThe 3" is the one I use most often and I wanted to make this out of scraps so I built it with what I had on hand. If it ends up not working well with the smaller diameters I'll look into some magnetic router table inserts and add some magnets to the table.
Don't leave magnetic sheeting on cast iron, it will collect moisture and rust the metal. I saw a truck door rusted through because he left a magnetic sign on it and never moved it. At least take it off once a week, wipe it dry, and oil or wax it.I have seen people use the magnetic sheet's for signage on their router tables. Don't know if that works or not. Cover the whole table.. an allow for a small square in the center to accommodate the bit size being used. Just change out the squares for the bit's
I just use it on the painted sheet metal sides of my saw, no worries there.Don't leave magnetic sheeting on cast iron, it will collect moisture and rust the metal. I saw a truck door rusted through because he left a magnetic sign on it and never moved it. At least take it off once a week, wipe it dry, and oil or wax it.
Back in the late 2006--08 before moving from Fl to TN.. The craftsman was cutting Lexan, sheet goods on his router table, an the table was sealed with the plastic matt, when I inquired it turns out the matt was this magnetic sheet good for making signage for vehicles, he used it for covering the router table, an 4x4 square were cut out's for different router bits.. For some reason cutting Lexan because it's shatters easily an the matt added a stable platform for cutting from what he was telling me. I have never cut plastic with a router.Yep, good reminder on the speeds. I've been using these drums with a jury-rigged setup for a while but I won't say I always remember to move the belts.
I have several of the magnetic sheets from ordering them to seal up table saw holes, not a bad idea.
