Wet turning
PChristy
Phillip
Just got back from TracyP's - I know no pics didn't happen - will post some pics of what I turned soon - anyway Tracy told me to put it in a brown paper bag with the shavings and store it in the closet for about six months - I have the brown paper bag and the shavings but what I don't have is the closet space - Do I need to keep it in the house or can I put it under the house in the crawl space -
TracyP
Tracy
I had a great time watching you turn that burl. Just put it in a dark place for a couple of months and it will be ok. The main thing is to let it dry slowly,
PChristy
PChristy
Phillip
A Dark place for the Dark side turnings:gar-La; under the house is a very Dark place for those Dark side turnings:gar-La;
Just don't set it on the dirt where bugs can get to it. Check it in a month, as cold as it is the rh is much lower.
walnutjerry
Jerry
Phillip---------another method for drying the turning is to put it in a plastic bag and each day turn the bad inside out-------when you do not see any more moisture collected on the bag, the turning has dried. It can be kept anywhere.
Jerry
PChristy
PChristy
Phillip
:eusa_thin hummm I didn't think about the bugs - I think that I will try to find a better place - are you saying that it needs to stay warm?
Ah... no.
The air is cold and isn't holding much moisture now, so the wood will dry faster.
Of course, you don't want it to freeze.
