Wenge Jewlery Box
dino drosas
Dino
I needed to get a wedding gift for a friend so I thought making them a box would be the way to go. I used Wenge for the sides and figured maple for the top. The insert dividers are mahagany and the inside bottom is tan leather. Finished in laquer then rubbed with wax and rotten stone. Made a few mistakes but it will do for the first one.
TracyP
Tracy
Great looking box. I really like the contrasting woods!!:icon_thum
NCPete
Pete Davio
sweet looking box, Dino.. now let me get this pic off the computer before LOML sees it. She still wants here cutting board!
Very nice box Dino. Great contrasting woods, and nice extra's such as the splines without making it too "busy". I noticed the grain is continuous over the feet, so I assume it was one big piece and you cut out the middle sections, as opposed to gluing feet on.
If you don't mind answering a few more questions....
The top, is that just glued into a rabbet?
Chamfer along the edge of the top ?
Roundover on the top edge of the box?
How did you do the splines?
As you can see, I haven't made any jewelry boxes yet....
Canuck
Very nice work, Dino!!:thumbs_up:thumbs_up:thumbs_up
(With my limited experience, I find that making small boxes with nice tight and square joinery, much more challenging than a large piece like a wall cabinet!:embaresse)
The wenge sure does look nice with curly maple!
I am sure that it will be treasured by the recipient for a very long time.
jeff...
User not found
Pretty Box Dino like the contrasting woods - but then again who wouldn't?
dino drosas
dino drosas
Dino
First, I thank you all for your kind words. I made some mistakes but will know better next time. The Wenge is not in my opinion a good wood to work with. It is very hard and dusty and the ends spilnter and chip out. Very simular to African Blackwood. I had one piece and used it up. I cut out two boxes from it and will probally not use it again (I have another Webge box ready to glue up).
Bas; There is a great article in the April 2008 issus of FW, #197 on building boxes that give all of the info you asked for. The top and bottom are not glued but float in a rabbett so that they do not crack with the wood movement. Box was glued together at the corners only and then the top cut off on the band saw. The splines were cut on the table saw using a 45 degree sled before the top was sawn off. I think that a biscuit joiner jig might even work better for the splines and will let you know .
dino drosas
dino drosas
Dino
David, I have a 1" carbide tipped blade on my band saw and the cut edges are almost as smooth as a table saw cut. To finish them I lay a piece of sandpaper on a flat surface and lightly rub the entire box on it , sanding all four surfaces at once. Do the lid the same way.
ScottM
Wonderful craftmanship especially with such difficult wood. :eusa_clap
