OK folks, I am officially baffled. :confused_ The maintenance guys replaced our old water heater with a brand new one (same size, etc) and the hot water STILL runs out after two showers (10 to 15 minutes each, 20 to 30 minutes total). The tank is located in our laundry room, which is heated, so I don't think it has anything to do with the colder weather. If anyone has any ideas, I am all ears.... :help::help::help::help::help:
Trent, it sounds to me like you have a water leak somewhere along your hot water pipes feeding your bath room or perhaps some form of blockage issue contained within a valve or the lines themselves.
Trent first things first: Do you know what type of pipes are underneath your house, do you have PEX pipe which is the plastic piping with compressed fittings, PVC type piping or ordinary copper pipes? Many forms of compressed type fittings apart from copper fittings are notorious for leaks so that might be a first place to check. Grab a flashlight, Don some old coveralls, crawl underneath your house and and just crawl along your hot water lines feeding your bathroom rendering a very thorough inspection.
Another thing you can do to check for potential leaks in your water service anywhere within your house of any magnitude is to check at your water metering device, if you are on community water or township water. Make sure no toilet, sink or washer is running inside your house, basically make sure all water is turned off and you know that it is. Go to your meter and check the guage, there will be a small central star shaped apparatus in the center of the guage, this should not be spinning if all of your water is turned off inside your residence. If it is spinning noticeably it is a tell-tale sign that you have a leak somewhere under your house. Sometimes it may move a little which is just fluctuating pressure in the service but if it is consistently moving at a set speed than you might need to go about hunting for a leak source.
Now, the next thing is there very well could be some form of blockage from within your pipes. Chances are if you changed your water heater, the other heater was old and the interior of the tank was deteriorated somewhat thus creating the potential for particles to enter your hot water line and they may have gathered in a fitting somewhere like a 90 degree elbow, valve housign, etc;
Flush your system thoroughly by opening all of the your hot sources, throughout your house all at one time.
Now if you are still having problems i would say it is contained within your shower head, i will be willing to bet that particles are blocking the fine orifices in the interior portions of the shower head thus blocking your water flow.
The best way to clean this out is to completely remove the head, either replace it or soak it in a bowl of vinegar for a while then rinse thoroughly. Sometimes upon closer inspection you will actually be able to see the small specks of metallic particles blocking your orifices in the head and can remove them with a small pick of some sort, but removing is still your best bet.
Please keep us posted. I am certain we can get to the bottom of this without you having to pay out ohter additonal monies right away.
