I just had some walnut sawed they are 12/4 boards and 12 foot long any Ideas at what there worth? I was going to use them for gun stocks but I dont need all I have. Any advice would be appreciated Thanks
Are you having it kiln dried?
The slabs are 10 to 16 inches wide and ive got them stacked now to air dry.. im going to pick up a moisture meter before long to check it because im curious myself at what it is now.I'd hesitate to cut a 12' slab prematurely, given the many ways such pieces could be used.
Once used for intended purpose, many turners (me included) would love any off cuts or left over 3" thick walnut for turning, especially if these were wide slabs (i.e. 10-12" wide or more). Of course in that case you wouldn't have to let them dry out - as twice turning bowls is quite common. Rough turned to general shape, set aside to air dry, then re-turned to final shape.
Henry
These are a few short pieces that I cut cut with my chainsaw of the 12/4 boards
Kiln drying may result in a washed out look. That's my understanding but I don't know the specifics of the do's and dont's.
Depending on conditions it may take another 2 years of air drying for the 12/4 material to reach optimal moisture content. Do you have a moisture meter to check content? The rule of thumb that I remember is about a year per inch of thickness drying time. But I'm no expert so others may have better advice.
I definitely prefer air dried Walnut to the Steamed and Kiln Dried stuff. This process darkens the Sapwood at the expense of the true color in the Heartwood in my opinion. Washed out is a good description of what the Steamed wood looks like in my opinion.
- Ken.
