It is Spring. Temperatures are climbing. The wind is blowing. Pine pollen is up your...tolerance level. Let's go outside.
This contest is outdoor "furniture". What have you made that sits by the fire pit or on the deck or maybe on the porch? Tree stand? Deck storage box? Those things you put plants in so that you can lift the plants out later and clean out. All the goodness that you've made to adorn your outdoor living space. Let's see what you've made!
This contest will end April 28. Voting will run April 29-31.
Rules:
-Must be created/completed within the last 120 months. That's 10 years, OBTW.
-One submission per creator/artist per category (month). Pick one piece. Chair, table, lounger. If you have a set and want to show how it matches okay but you are only entering one piece. Hight light that one piece.
-Members vote for winners so your submittal 'marketing' post should reflect quality. Limited to 3 photos and 500 words. One post per submittal.
<space>
- Any Q&A regarding a submittal should be handled by separate post, or DM/PM. Expect questions to be deleted. Separate posts do not clutter the contest thread, avoids vote biasing, and everyone can share How's It Made (Resources forum content).
-Each creator can win a contest no more than once every six months.
-In case of a tie, a judge panel will make the selection. Judges' decision is final. Judges will remain anonymous.
-Each monthly contest will have two winners, novice and experienced/journeyman/veteran/pro. Novice is defined as <3 years woodworking, cumulative. "Experienced" is all others. Submitters must indicate if they are novice; honor system applies. If you don't declare, you're an experienced woodworker.
Rules:
<space>
