Hi All Thought I might post something tangentially related to woodworking.
Tape(s). I had to give a discussion to our rank & file on this in the past so figured I would share some of that here.
We all use tapes of various kinds in everyday life. Often, we are using what we have and sometimes using the wrong kind sometimes without knowing we are do so.
Some tapes the adhesion gets better over time. Others the intent is to allow it to stick but be removed in the future without damaging what the tape was stuck to.
You can tell cheap tape from good quality tape. Don't make your job hard because of poor quality tape.
You know it is funny, I have been involved in many Construction defect lawsuits and one of the common reasons is water infiltration. One of the common causes is cheap caulking.... They build a 10 million building but cheap out on the caulking ?... So getting the right material for the right application is key to a great job.
The best advice is to know what you want the tape to do, know your vendors and know who always has fresh stock.
Attached, are some pictures of different kinds of tape Labeled 1-22.
#1 & 5 are your typical electricians tape. If you are really doing any serious electrical work, I recommend you buy good quality tape. A lot of the Home Depot type cheapo stuff has a poor adhesive which typically does not stay stuck over time.
#2-3-4 Are electricians labeling tape used to designate a specific wire a certain color or to make identification easier. This is often used when you do not have or run out of a specific color wire. When needing a ground, a white wire will have it wrapped on both ends with green roughly 12 inches to designate it as a ground. Although labeling tape is made of the same material as the regular electricians tape, it usually is slightly thinner and not as wide. It is not normally used as a spicing tape or a wrap on the wire nut, unless you are trying to i.d. .........though I have used it like those situations when necessity requires I end up wrapping a lot more tape.
#6 is Pipe Wrap tape, Usually comes in 10 mil or 20 mil. It is used on gas line in some cities where they require all gas line in the ground to be wrapped, or require all joints to be wrapped. Mostly, in Hawaii, we use it to wrap plumbers tape (that metal thin strip materiel that has holes in it) to insulate the metal from gouging plastic when supporting ABS of PVC pipe.
#7 is Rubber splicing tape used in splicing electrical joints. It sometimes is used with a liquid coating as well. Biggest advantage to this over PVC based electricians tape is is is stronger and thicker. There are other reasons that some of the electrical minded gurus in this forum will likely chime in and add. I have also used it for making temp repair to a pipe in a pinch with a hose clamp. It does work.
#8-9 are duct tape. There are several varieties of duct tape. The strongest with the best adhesive being the gaffers tape version. Nowadays, in HVAC we really do not use it all that much mostly because there are others that perform better and prevent callbacks. The "Duck-Tape Brand Shur-tape inc?) has a manufacturing facility I think in Hickory. They have a festival once a year, kinda fun to take the kids to.
#10 is strapping tape we all know that stuff... great for shipping, but also a quick fix to consolidate heavier materiel you need to lift.
#11 is double stick tape. If you need this to have great holding power get this from an autobody repair supply. The stuff they use on cars to stick the labels and insignias is what you want. It sticks and does not fail.
#12 is Scrim Tape for duct board assembly and HVAC. This stuff is what you want to use on anything cardboard. I lined my wood scrap box with it and still have the same cardboard box 3 years later.
#13 is something that like like other pvc tapes but sticks like all get out. It is Hipp-wrap tape. I use this to fix things that need strength and will not fail. Its designed use is to tape a kind of 6-10 mil think white plastic over things for longer term storage, then you use a torch to shrink it. You all have seen pallets with that white plastic shrunk over it. This is the tape for that. - Great stuff
#14 is Venture tape. It is usually used on duct connections of all kinds but because it is all metal, it can have some pretty cool uses. One in particular is shimming some metal object up 2-3 thousandths. Because it is metal it does not compress and change. There is another variety of this tape that has heat adhesive on it for taping "B" vent connections. Heat exhaust connection from a furnace. Looks the same but it is not the same adhesive.
#15-20 are various grades of masking tape. The blue tape used to be called 1 week tape because you could leave it on for one week without it drying like traditional tan masking tape. My advice on and masking tape is this: buy from someone who is always turning over their stock. That way, you do not get old tape. Also, if you really need the best masking tape get it from an autobody painting supply shop. The orange and pinkish ones are better at edge sealing than the 3M blue one. Once again, check with you vendors and the better local autobody shops and find out what they use to prevent painting bleed on a taped off area.
#21-22 are just the typical 3M clear tapes. If you are intending to ship something correctly, get the better shipping tape seen in the pix, the cheap stuff does not stick well, it is thinner and you end up using alot more to do the same job. So, not really that great of a saving.
There are many others, but were the ones I had in my garage.
