I am continuing my panel flattening journey, first mentioned in Router for Slab Flattening Sled
I hope the pics appear correctly. I am practicing on a glue up which had been sitting around for years.
I use a 2" diameter bit, which is $17 off Amazon. My plunge router is a 2 1/2HP Milwaukee. There was no issue with overloading the router motor.
The bit shaft is 1/2" diameter, 2.5" long. I insert the shaft 1" in the collet.
The router base is 3/8" thick, the sled bottom is 5/8" thick.
The max cut depth using the sled is 3/16".
I include before and after pics of the shelf. There are marks where I took a "deepest pass", for illustration.
Suggestions, ideas, and critiques are appreciated.
