I think you are right Fred. I think I will let it run for a hour and set the belts. When I was in production these things ran 8 hours at a time and I never changed belts. I think they have developed a set.
does it smooth out after running a while? if it's just the belts taking set it should smooth out. you should not need new belts every few years as a hobby saw. Mine is a 1948 and untill I bought it they were using the original belts! that was their story anyhow. they were shot but still worked. try a different blade. possibly its out of balance. I do not recomend link belts on a unisaw.
Care to give us some insight as to why?
because it's a 3 belt drive and they should be matched belts. link belts tend to stretch differently than V-belts and others that have done this have said the vibration was worse. link belts work great on a single pulley system. :wink_smil
Thank you for the info, Fred! You probably saved some of us some money!
