Unexpected difference
tvrgeek
Took off my Diablo 80 tooth fine tooth blade for my miter saw as I got another Amana full kerf 80 tooth. I was expecting slightly more force, same smoothness but less curve in a compound miter.
What I got: Cuts so easy you almost don't know it is cutting! As expected, cut is about perfectly smooth so no difference. I will test the compound miter today. I have to look up specs, but I think both are ATB 10 degree.
Went to a 60 tooth on the TS. ( Amana) Better all around for solid wood. Going to see if just going to two pass cuts is better than fancy ply/melamine blades.
