Took much longer than anticipated but 2 shoulder surgeries, and then waiting for warmish weather so I could apply the finish but the TV stand is now done. It is Hickory. Are floor down stairs is Hickory and teak and really liked the look of the floor so wanted to have a similar look. It is about an inch and a half thick and much heaver than planned so it have to come up as three parts and then used pocket holes to screw the tops on. The bottom are glued mortise and tenon. The Finish is Waterlox with a hand rub style with the last goat sanded to 600 grit and then a polishing compound applied. Was trying to go for a modern rustic look and turned out pretty close to planned.
