Turning(?) project finished!
Michael Mathews
Michael
I started this project on August 17th. The blank was turned into a bowl approximately 9 in in diameter and 5 in tall. The wood is ash. After using a trim router with a 1/16 inch router bit I began to cut randomly shaped fingers in the rim of the bowl. Next I used my Fordham flex shaft power Carver along with a course flame Burr to shape the fingers very carefully as I did break a couple of them off. I learned quickly that they had to be supported on the back side because a small vibration would cause them to snap off. Next I switched to my Proxon power Carver with very small diamond Burrs to smooth out the cuts made by the course burr. Finally, I 3D printed a custom sanding fixture for my multi-tool so I could send each finger on all sides. And then using my Dremel tool with a 90° head I used a one and a half inch flap sander to sand everything smooth inside and out. The Finish is a polyurethane Clear Satin because there was no sanding or buffing required after the Finish was applied.
woodlaker2
Ray
View attachment 241353View attachment 241354View attachment 241355View attachment 241356View attachment 241357View attachment 241358View attachment 241359View attachment 241360
Very creative Michael. Haven't seen too many with such a design.
drw
Donn
Michael brought this to the most recent RDU Lunch; while it looks impressive in the posted pictures, when you actually hold it you become particularly aware of piece's delicacy. That said, it is a very beautiful example of artistry and craftsmanship.
mattfrit
I'm curious Matt? What kind of ideas does this piece drum up? Now you've piqued my interest!!
These fingers look awesome, but a little precarious to me. Im thinking that it might be possible to fill in the empty spaces between the fingers with tranparent or lightly dyed resin, which would add a lot of strength without taking away from the delicate carving. Along those lines is a a small bowl I turned years back with broken wood pieces. Picture hopefully attached.
Of course, I also have a bit of a resin problem. I put that sh!+ on everything.
