jeff...
User not found
I had a couple of members PM me about a while back about how to make turning blanks, so I decided it was time I posted some pics on how I make em.
Comments / corrections / beatings with wet noddles are always welcome.
First sharpen your chain to a good rip angle don't try this with a cross cut (standard grind angle chain) right around 20 degrees works pretty well - suit up with the necessary safety gear, boots - chaps - face mask - ear muffs - gloves and the like. Understand the dangers of running a chainsaw / don't cut off your arm - they don't sell arms at walmart :gar-La;
Secure your log cookie with wedges or whatever (Wood is best - not steel for obvious reasons). Cookies should be approximately 1/2 as long as the they are wide. So if you got a 40" diameter log, right around a 20" long cookie will make a pretty good turning cube . But if you want a turning square longer than it is deep, just cut your cookie off the log a little longer like shown in the pics to follow. Think about your swing handicap on your lathe, just how big a square can you turn? Make 3 cuts like this...
Then make your 4th cut - you don't want to split the log cookie down the middle - you want to make cuts on either side of the pith (center of the cookie) Pith in your turning squares is bad - it's usually splits and that will mess up your master piece. (Hint: don't buy pith ridden turning squares)
Finish off your two center cuts - the pith ridden piece in the middle makes for good fire wood kindling - or if your over zealous, trim out the pith for pen blanks
Now trim the sides like this.
Here's what your left with - an unsealed turning blank (you get two of these per cookie).
Important... immediately seal the entire square in Ancoseal.
There you go - it once was round, then it was square but some darksider will make it round again.
Make sure your buddy is around to be on the look out for bad'ens (fury four legged creatures)
Thanks
Thanks
