I did some checking. Called Oneway and he said they sell an adapter to screw onto left-hand threads but that mine already should. I checked and it does. :wsmile: So next question... in class the largest we can turn is 15". Assuming I were to do that, the tenon or mortise for the chuck would warp when the bowl dries, no? I expect the way you fix that is after it dries to put it back between centers to get the tenon round again, correct? Problem is, I won't have a tail stock to put it back between centers. If I were to mark the center of the bowl on the bottom with a very small mortise, then glue a tenon on after it dries with a locator pin, would that be enough to turn the tenon/mortise round on the bowl so I could rechuck it?
