Eagle I respect your opinion and input. Thanks!
I bought the blank from Woodcraft and it said blood wood. They could have made a mistake. The color is much richer in person. I don't have a real photo booth and I think the flash washes out the color. I've actually been tempted to just leave the wood natural. Have you ever done that?
I rarely buy precut blanks.
I recently got some
GREAT DEEP RED bloodwoodat the Charlotte Klingspr.
It is rough cut so it was a generous full inch.
I don't buy planed stock if I can help it.You'll be amazed at how much you can save whenyou buy lumber instead of blanks.
Aslo you have the option of cutting in different orientations .
Those who sell precut blanks want the most blanks from a ppiece of stock,I am more interested in getting the best looking.
Take a piece of stock ,cut it straight grained turn a "dowel" sand and finish as you would a pen.
Take the same species of stock and cut it on the bias.
Turn a "dowel"(remember to stabilize with CA as you go and use scray shrap tools) sand and finish the same as you did on the first piece.
Compare two.
The proof is in the finished product.You will find yourself turning more "angle cut stock and let those who have money to burn buy precut blanks.
You will have the more interesting finished pen.
(If you turn your "experiment" to a 3/4 dia you will still be able to make a pen out of it.Nothing wasted)
I have left some "natural", ebony is a good example but it still needs a protective coat.
For that I use TSW.
If you are going to use Mylands high build polish, use their cellulse sanding sealer first and their 3 step method.
3 coats of sealer(put on like a fristion polish) 3 coats of high build polish(friction application) and 3 coats of carnaube wax.
Let cool between applications.
It will "mimic a CA finish but give you more "depth"
