Project w/ Pics Trim week at our new house
Danny Batchelor
Danny
Your pix and explanation are so good I feel like I could do this but the contemplation of all that future routing is way, way beyond my ever attempting anything like this.
creasman
creasman
@Danny Batchelor You may surprise yourself. I try to break everything down to a process. Sometimes my first attempt at a step is a fail and I have to rethink and try again. Eventually, you get a working set of steps. Then it becomes rinse and repeat until you are done.
For example, my first thought was that I could glue and bend all four sets of strips for the casing at one time. That did not work and I ended up scrapping a set of strips I'd worked on. The solution was to take it slower and only do one section at a time.
I won't lie. It was time consuming to make 16 sets of casing for the arches. However, after the first 3-4 I had it streamlined and it was just a matter of keeping something in the clamps.
Thanks for the feedback. I'll be posting another set of instructions covering the jambs soon.
creasman
creasman
Jambs (Part 1)
The arches are installed in walls framed by 2x6's. To make the jambs solid would have required me to laminate a curve that was almost 7" wide. This would have been difficult with my setup. More importantly, it wasn't the look I was going for. The thicker walls allow for a framed panel design.
These are the basic details. The rails and stiles are moulded with a quarter round bit from a raised panel set. The panels are flat in this case. There isn't much width for having a raised panel. The stiles are 1-3/4" wide, leaving about 3" wide panels. There are three short rails on each side that follow a Fibonacci progression from the top down -- 3", 5" and 8". The placement of the middle rail divides the side in a 2:1 ratio. The arch panel extends all the way across unbroken to the other side. I'm not sure any of this matters, but I like to have a reason for where I place things.
The side jambs were assembled separately, including bottom, middle and top rails. The side panels are 1/4" plywood. At assembly time the arch panel is inserted into the slot of the top rail. You'll notice the joint between side stile and arch stile are right below the top of the top rail.
The arched section of the jamb requires three curves to be laminated. The rails are about 13/16" thick, composed of seven layers. The panel is only 1/4" thick and is three layers. I first tried to coax the 1/4" plywood into bending, but it only ended up breaking. I thought about buying the plywood made to bend, but decided to laminate these as well. The outside layers are about 3/32" thick and a middle layer is only 1/16" with the grain running counter.
For the rails I began with strips 2" wide, arranged these in the order I wanted, marked the middle and then laid them out to apply the glue. Hold one strip back to avoid applying glue to the outside of the packet. Marking the middle helps you realign the packet after the glue is applied and helps position the lamination on the middle clamp.
Apply the glue using the applicator. Make sure to get an even spread without any bare spots. Finally, restack the strips and wrap each end and the middle with stretch wrap. This holds everything together while you're adding clamps.
Start clamping in the middle of the curve and work towards the ends, alternating from side to side as you work. Keep the steel bars and the packet firmly on the base as you go around. The Titebond Extend gives you about 20-25 minutes to get this done -- plenty of time. Don't panic.
The first layer is one of the steel bars. I found it easier to bend this around and temporarily clamp it while I was working on the rest. Use hand-release clamps as an extra set of hands. Finish with the second steel band before using a second bracket and a C-clamp to lock it in place. I found it easier to elevate the packet on 2-by blocks. That's the yellow blocks you see (yellow painter's tape to prevent the glue from sticking).
Glue up for the panels followed a similar approach. However, I used a strip of poplar 4" x 1/8" in place of the inner steel bar and then stacked the steel bars on the outside.
It's good to leave everything in the clamps for at least 12 hours. I find the Titebond Extend also takes longer to fully dry. The stile curves had no spring back after removal from the clamps. The panels did spring back slightly, but I was able to force these into the stile groove when the time came.
In the next post I'll describe how I routed the groove and assembled the arch jamb section.
creasman
creasman
@Danny Batchelor asked a good question about why you extend past the horizontal. I meant to discuss this in the previous post. This photo illustrates why you need to go beyond the intended length when laminating the arches.
Note the ends of the packet. The strips are all the same length. However, the distance around the curve is longer for the outer layers resulting in an uneven end. It would be difficult to cut and then bend the lengths so they all ended exactly at the desired location.
Another issue is that of planer snipe. Even 1/100" of snipe at the end of a strip will result in a 7-layer packet that is over 1/16" thinner at the ends.
For these reasons it's best to extend 4" - 6" beyond the cut line. This will be removed and discarded later.
Wilsoncb
Williemakeit
Thanks for all the details. I’ve done some bent lamination work with “regular” PVA type glue like you described without any issues. However recently one of the local woodworkers in our local group gave a presentation and said bent lamination are best done with Urea resin (Unibond 800) to avoid creep.
I found this article that addresses this and interestingly mentions Sam Maloof also used PVA glue.
The other little detail I noticed was the steel strips you used in your clamp up. You look like your glue-ups are much cleaner than mine. I inevitably get glue everywhere, so I apply tape to the steel to avoid stains where the glue inadvertently gets onto the steel.
creasman
creasman
I had not used this version of Titebond before. It was recommended in the video tutorial I watched. My experience is that when you get above 4-5 layers in the lamination there is no spring back. I know that's not the same as creepage.
I don't have experience with that many different glues. I use Old Brown Glue (liquid hide glue) for most of my furniture to avoid having glue stains in the finish, hot hide glue for veneer work, and one of the Titebond varieties for everything else. One of the mistakes people make (including myself) is to take off the clamps too soon. The Titebond Extend seems to want a good day to fully harden. One of the wonders of hide glue is that it bonds both chemically and mechanically. It's also very brittle once it dries. I have had problems using Titebond Extend and Old Brown Glue in a vacuum press as both take too long to set.
Iron staining would be a concern if I weren't painting. I'm sure I had some of this along the way. I made the strips wider than necessary, jointed one side and then ran each through the surface planer. Typically stains are where the glue squeezes out and touches iron. This surface was removed by the planing.
Wilsoncb
Williemakeit
By coincidence Woodsmith just came out with an article on doing bent laminations. They are recommending epoxy. They are also saying you can soak the strips in water to help bend them in some cases. Personally, I would never use epoxy or soak the wood (I would just cut the strips thinner). If there’s one thing I have learned about woodworking is, there are multiple ways to do anything. I think the “right way” is what works for you.
Thanks again for taking time to share your experience, knowledge and process.
creasman
creasman
Jambs (Part 2)
The arched part of the jambs consists of three pieces, the two stiles and the panel. I pre-assembled these as a unit and glued the panels in place. Later, at installation, I attached the side jambs.
Before removing the stiles from the clamps I marked the places where the major and minor axes crossed each. This was done by first squaring up on opposite sides and then marking across. From there I could extend the mark down both faces. These became important reference lines later to guide the alignment. If misaligned the arch assembly could end up slightly twisted.
I jointed one edge on each curve and then ran them through the surface planer down to the proper width. The moulded edge was pretty easy to do in spite of the curve. I used a round over bit in the router table with a pilot bearing to create an edge profile to match the one on the side jambs.
The challenge was to cut a quarter inch wide groove around the curve. To do this I created the jig shown below for the router table. It overlays the table and is secured using T-nuts in the miter track. Besides the hole for the bit I added a hole to allow access to the height adjustment. A bolt extends through the base with two roller bearings stacked. On the other side of the bit I have two "bumpers". These are bolts with a spring underneath. Together these three points helped me navigate the curved stile as I ran it over the 1/4" bit, keeping the inside of the curve pressed against the roller bearings.
One additional aid was to draw a reference line parallel to the bumpers. As I fed the stile through I could gauge the orientation by seeing how much of the line was exposed. If you can see the same length on both sides of the bit as you feed the stock then you know you're on track. Not an exact science, but the results turned out very good.
With all the machining done I could assemble the stiles and panel. This is where the alignment marks were used. By aligning the reference marks from the minor axis (middle of each curve) I could be sure I wasn't distorting the arch. It's a good idea to mark each stile and panel set so you can keep them together.
Once assembled the reference marks from the major axis are used to know where to cut the ends. These identify the location where the arch jamb joins to the side jamb. For my design to work the stiles and panel all needed to be cut at the same place. That's a challenge when you have a 60" long arch that is 12" high and over 6" wide. The only tool I had to easily do this was my 18" bandsaw.
I made a jig that would keep everything in place and hold it securely as I fed it through the bandsaw, using the rip fence as my guide. The base of the jig is 1/4" plywood that is slightly wider than the arch (about 14"). A "T-bar" marks the major and minor axes and extends upward to align both rails. The arch is held in place with screws that are removed after cutting. The saw blade just brushes the major axis as you feed it through. The only wood being cut is at the ends of each arch.
Once the ends were cut off cut and glued spacer blocks around the length at 8"-10" intervals. These secure it in place at the proper width for the jamb. It's now ready to attach to the side jambs, but that didn't happen until I was ready to install each arch.
Next post will be about making the casing used around the arches.
creasman
creasman
Casing
You may recall from my earlier post that the casing consists of four parts -- a round, ogee, flat and bead. Whether curved or straight the process used was the same. That is, make each part then glue the four parts together to make the whole.
Curved Casing
The first step in making the curved casing is to adjust the brackets on the form. Each bracket is moved 1/4” outward from where it was set for the jambs. This is done so the curve creates the required reveal as it wraps around the jamb.
I suppose you could continue adjusting the brackets outward to make each section. I found it easier to leave the brackets in place, along with the inner layers, as I glued up the next part. This ensured a precise fit when it came time to glue them together.
It’s also best to make the blanks for the curved parts around 2” - 2-1/4” wide since the steel bands I used are 2” wide. I then ran these over the joiner, ripped and planed them down to the size required. For example, a blank composed of three 1/8” strips 2-1/4” wide was sufficient to cut three of the inner sections (i.e., the bead).
Moulding each section was done on the router table with the fence removed. I used a simple quarter round bit to make the bead and round sections. The ball bearing serves as the guide.
This was true for the ogee section as well. However, this section required multiple passes and a bit more finesse, especially when starting a section. To simplify things I screwed a starter pin into the table top. This gave me a solid point of contact so I could ease the blank into the bit.
Once each section was complete I used the same setting of the brackets when gluing these together. I glued two sections at a time, starting with the bead, to make it more manageable.
A bit of patience and you eventually end up with casing that perfectly matches the jambs.
Straight Casing
The straight casing is composed of the same four sections, each made separately using the same bits and then glued together. The only difference is you aren’t dealing with laminating a bunch of strips. The process goes much faster.
It is worth noting how to glue the strips together. You could use a lot of clamps. This could get very fussy and difficult to keep them aligned. I was able to use only four special clamps along with a fixed fence and a stiff, straight board.
I did the glue up for these on a melamine surface. The glue doesn’t stick so the squeeze out on the back side isn’t a problem. Each of the four piston clamps are mounted on a scrap board and elevated so the rubber end is at the right height to center the pressure. These are then clamped to the melamine base using two C-clamps.
Here’s how the clamping station looked when in use. I glued two sections on two pieces of casing at a time, beginning with the bead and flat sections. Once all these were glued I adjusted the back fence and added the ogee sections. Again, two pieces at a time. Repeating this pattern I made over 400’ of casing, enough to trim the doors and windows for the main areas of the house.
Apologies on the delay for this post. I had the whole write up ready and my computer crashed... lost it all. I didn't have the heart (or time) to organize it all again until now. In the next post I'll describe how I assembled and installed the arched openings.
