This week I took a break from making cabinets for our new house in order to install the trim. The first part of the week was spent trimming out several elliptical arched openings throughout the house. I began working on the casing and jambs for these last November as soon as we had finalized the plans. In addition to these openings the front door is round at the top and two of the windows have arcs. The job required a fair amount of custom trim to match all the curves. Add to this the several hundred feet of straight casing required and you see why I started last year.
We're pleased with how it all came together. I used poplar for the casing since they will be painted. The technique used to form the curves is bent lamination using 1/8" thick strips and lots of glue. This method was used for both jambs and casing wherever a curve was required. There are other ways to make this sort of trim -- CNC, specialized moulding machines, urethane trim, etc. I chose the method that fit my budget and didn't require purchasing any specialized equipment.
Below are a few pictures. I'll add more posts to this thread explaining the design and process I followed.
There are eight elliptical arches -- three 60" wide and five 36" wide.
The front door has a semi-circular arch at the top.
Lastly, two of the windows have circular arcs at the top.
