Tool Score!
navy1990
So I was helping a friend from church move today and we got to cleaning out his shed. I was moving items to the truck when I picked this up.
View image in gallery
He told me not to bother putting it in the truck because it is broken. I told him (quite boldly) that I can fix it. He said that if I can fix it, it's mine. It's a 125 PSI, 3 GAL Craftsman air compressor. I don't know what's wrong with it or what it will take to fix it, but I'm sure gonna give it my best shot at fixing it. I'm sure I will probably be asking for help on here from time to time while fixing it.
Matt in Jacksonville
LeftyTom
Tom
It is worth a try. Is all else fails, you can see if you can get a working model, and you've got spare parts!
FredP
Fred
looks like first step would be a dip stick plug. it appears to be missing. check oil level, fire it up and see whats wrong. depending on what you find it may be a great deal.:icon_thum
navy1990
I will check the dipstick plug, but I found out a problem. The piston is frozen on the drive rod. Everything else moves freely, except the piston doesn't move on the rod. Any suggestions on breaking it free?
FredP
Fred
take the head off and fill with penetrating oil. let sit for a few days and try tapping with a mallet. if it dont move get a bigger mallet?:gar-Bi
the parts may cost more than the compressor did when new.
If this is an oilless compressor, the piston & rod are made one piece and do not move independently. Does the piston have a skirt? Does the compressor have a crankcase? If not, it is an oilless. The connecting rod rides on a ball bearing bolted to a counterweight that is direct coupled to the motor shaft.
